madhu_tanniru1 SEFI Member
Posted: Thu May 26, 2011 10:27 am Post subject: Box Girder bridge Design |
Dear all,
I need to do manual design of concrete box girder for a bridge. Could any one suggest any reference material.
Thank you |
B.V.Harsoda General Sponsor
Posted: Thu May 26, 2011 1:32 pm Post subject: |
Bridge Design Group | | 1 | Bridge Concrete Girder | Prestressed Concrete Girder Design for Bridge Structure Based on AASHTO 17th Edition & ACI 318-08 | 2 | Bridge Concrete Column | Bridge Column Design Based on AASHTO 17th & ACI 318-08 | 3 | Bridge Box Section | Bridge Design for Prestressed Concrete Box Section Based on AASHTO 17th Edition & ACI 318-08 | 4 | Concrete Tunnel | Concrete Tunnel Design Based on AASHTO-17th & ACI 318-08 | 5 | Double Tee | Prestressed Double Tee Design Based on AASHTO 17th Edition & ACI 318-08 | | |
Posted: Thu May 26, 2011 1:42 pm Post subject: |
Bridge Handbook |
Posted: Fri May 27, 2011 6:48 am Post subject: boxgirderbridge |
thank you sir for your help |
atul_123 ...
Posted: Fri Jun 17, 2011 10:31 am Post subject: |
thank you sir for this xls files for design but all file design as per aci code.
do you have any xls file wich follows indian code?
B.V.Harsoda wrote: | Bridge Design Group | | 1 | Bridge Concrete Girder | Prestressed Concrete Girder Design for Bridge Structure Based on AASHTO 17th Edition & ACI 318-08 | 2 | Bridge Concrete Column | Bridge Column Design Based on AASHTO 17th & ACI 318-08 | 3 | Bridge Box Section | Bridge Design for Prestressed Concrete Box Section Based on AASHTO 17th Edition & ACI 318-08 | 4 | Concrete Tunnel | Concrete Tunnel Design Based on AASHTO-17th & ACI 318-08 | 5 | Double Tee | Prestressed Double Tee Design Based on AASHTO 17th Edition & ACI 318-08 | | |
erum SEFI Member
Posted: Mon Oct 14, 2013 5:08 am Post subject: |
Though it contains useful info, note that it is old. You may also ref the book on Transmission line towers by Murthy and Santhakumar, Tata McGraw Hill. _________________ erum |
es_jayakumar General Sponsor
Posted: Mon Oct 14, 2013 10:23 am Post subject: |
The referred book is out of print, it seems.
E S Jayakumar |
rajancivildesign@gmail.co ...
Posted: Tue Oct 15, 2013 2:11 am Post subject: Design of Box girder bridge |
There are many text books in the market for Bridge design , Among them Bridge Design by Jagadish, Krishna Raju, Vazirani are some of the text books. Whether these books fulfill your requirement or not. MOST have published some ready made design of type design for Bridges, If available you can refer. It does not contain any design.I herewith attached one report on simple bridge using Staad Pro for your reference.
V.M.RAJAN. |
